Greetings
Hey Mr. Cuss, my wife's Nissan Frontier has a problem with a slow freon leak & I remember I saw in one of your posts that when you were a mechanic, you had great success stories with some stuff that you use to add to a/c systems to seal a leak.
Is Red Angel the stuff you use?
Mechanic will NOT work on a system that's had sealer in it, will RUIN their expensive equipment, so they test for that.
Use UV dye, electronic sniffer, soap bubbles, and/or visual examination for oily residue to find the leak, and then repair the leak, evacuate, and re-fill with correct amount of refrigerant by weight.
AC work is significantly more involved than stuff like installing a radiator, water pump, etc.
Nope. I don't do any "miracles in a can" !!! No oil additives, no carburetor/injector cleaners, etc.
GlowingPiston
09-02-2019 06:51 AM
