Headlight Recommendations?
Old 07-13-2024 | 09:18 AM
Cusser's Avatar
Originally Posted by MeB2000
On Phillips screwdrivers.......a Klein #2 Phillips screwdriver is one of the best tools for theses trucks. I do use a small battery drill/driver also, but it seems that you have more control with a screwdriver when the fasteners are hard to remove.
I have learned that "Japanese" vehicles like this actually use JIS head screws, NOT Phillips. So I just recently bought a #2 JIS screwdriver through Amazon for my B2200 and Frontiers.
I also read that some folks take a #2 Phillips a blunt the tip a "tad" on a grinder to make it fit JIS screws better.
Old 07-18-2024 | 12:47 PM
esperado's Avatar
ok, some updates:
i still couldn't get the screws out, so i just unscrewed the whole headlight housing and slipped the replacement lights in, but they dont fit, so i'm going to return them.
i also got replacement belts for the alternator and AC. couldn't figure out why the AC adjustment bolt wasn't loosening the belt tension, but since the AC doesnt work anyways, i just left it as is and swapped the alternator belt (which badly needed replacing as it was old and too thin anyways).
the lights are a disappointment, but i feel good having gotten at least the alternator belt swapped.
Old 07-18-2024 | 01:22 PM
It has mostly to do with the lens. It is also why I recommend the brand I did. I know the original manufacture long before they sold and were bought be another top aftermarket company. The lens clarity is extremely exceptional which directly affects the illumination brilliance.
Old 07-19-2024 | 08:31 AM
Cusser's Avatar
ok, some updates:
I also got replacement belts for the alternator and AC. couldn't figure out why the AC adjustment bolt wasn't loosening the belt tension...
The AC compressor is held in place by about four bolts and screws, and all must be loosened so that the compressor can be rotated to install/loosen/tighten the belt. If your AC is not working anyway, agree to just leave the belt off.
Old 07-22-2024 | 11:02 PM
esperado's Avatar
makes sense it's officially on my list, thanks!
Old 07-22-2024 | 11:03 PM
esperado's Avatar
that sneaky fourth! i'll have to take another look at it, thanks
Old 08-01-2024 | 03:23 PM
esperado's Avatar
just got back from a road trip with my brother in law, and had a new headlight waiting for me when i came home!
i had to use a file to make a groove in the four screws that were completely rusted into the housing, and i was able to carefully work them back out with the help of some penetrating oil and a flathead. then it was simple! everything is looking good, i'll just have to adjust once it gets dark out, but looks functional so far. very happy with it!
regular; passenger side holley retrobright | driver side waiting for replacement
hi beam; passenger side holley retrobright | driver side waiting for replacement
Old 08-02-2024 | 07:41 AM
MeB2000's Avatar
Good job Esperado!
Marigeebaby
10-31-2020 03:37 PM
aleong
11-21-2019 09:36 PM
aleong
11-21-2019 07:53 PM
Sara Johnson
08-20-2014 04:21 PM
JimMayor007
07-01-2007 03:04 AM
Quick Reply: Headlight Recommendations?
