Idling really high
Old 12-24-2007 | 01:40 PM
omanitsdan's Avatar
Default Idling really high
hi. i've got a 1993 b2200 p/u. it runs pretty good, but one problem i'm constantly having is the idle speed. i don't have a tach so i'm not exactly sure what its idling at but at it's worst it sounds like i have the gas pressed down about 3/4 of the way, when i'm just sitting at a light in neutral, either w/ clutch in or just out of gear, same thing happens. then as i let off the clutch to go, it quiets down and sounds perfect, but as soon as i put it back in neutral at any point, it idles really high again. i'm not really a car person, but i'm willing to learn anything so you might have to put some stuff in layman's terms. thanks
Old 12-27-2007 | 11:05 AM
travellingfire's Avatar
Default RE: Idling really high
Just had the same problem with my '86 B2000... after playing arownd with the carb and lubricating the linkages it would drop back to a normal idle (for awhile). I had the carb replaced on my truck and the mechanics didn't put the vaccum hoses back onto the correct spots... that seems to have done the job.
dasooey
06-04-2017 12:34 AM
brishan
01-20-2009 09:28 AM
XXBXDUBBXX
09-21-2007 08:26 PM
beartoes
06-12-2005 03:34 AM
Quick Reply: Idling really high
