Mazda b2200 part name?
Old 09-30-2020 | 08:18 PM
daddyof1234's Avatar
Default Mazda b2200 part name?
Name of the ignition part that mounts on the distributor that is approximately 1/2" X 1/2" with a little black wire attached to it? The wire then connects to the coil. The wire broke off the little block. My truck is now running rough. Thanks
Old 09-30-2020 | 08:29 PM
boozehero's Avatar
Have a picture??
Old 09-30-2020 | 09:27 PM
not at the moment. It mounts to the distributor near the engine block. It has a small wire that is in it that connects to the coil post.
Old 10-01-2020 | 12:37 AM
The Lizard King's Avatar
Originally Posted by boozehero
Have a picture??
He's talking about this square thing in this picture just to the left and above the distributor vacuum advance. I'm not sure what it's called. The black wire leads to the coil like he said.
Here's another pic of it (from a different truck).
Old 10-01-2020 | 09:09 AM
Cusser's Avatar
That's a capacitor/condenser; folks have used ECH RC111 or FA83 or P13045 from NAPA
I have such aftermarket condenser on my own B2200. If your black rectangular condenser still has a wire nub sticking out, solder a new wire onto that.
I believe this is mostly for reducing radio static.
Old 10-01-2020 | 10:09 AM
Okay thanks. Mine broke of smooth.☹️.
Old 10-01-2020 | 04:53 PM
Mine broke off with no wire left hanging.
Old 10-01-2020 | 09:47 PM
https://www.napaonline.com/en/p/ECHRC111
Old 10-02-2020 | 07:57 AM
Cusser's Avatar
Yep. Mazda number is S101-66-991
Old 10-14-2020 | 05:54 PM
Unhappy
Just to update on the little black wire to the little black box. The truck still runs rough. It will run a little better when you give it gas, but it is so weak. It sounds like the valves are rattling. While the truck was idling the end of the little black wire touched the distributor and killed the engine. I guess it blew a fuse. Only the dome light & horn work. The ignition part will not come on when you turn the key.
Quick Reply: Mazda b2200 part name?
