Mazda Wiring Issues
Old 05-15-2024 | 10:15 PM
Anarchy99's Avatar
Default Mazda Wiring Issues
So, I am once more back with my B2200. After some hiccups with wiring in the radio, I got everything in. I tested my wires one last time, before turning on the radio. I have noticed that the constant power wire has zero power going to it, wether the truck is off, in acc mode, or is fully turned on. The oppisite can be said for the acc wire, aka the red/black wire. Which has 11volts, while the truck is off and while the truck is on, it has 13v. From what I know, the accesory wire, should be wired into the tail light fuse, which it is. The lights were off at the time. Fuse was good, wiring was semi decent. It was powering everything when I had tested that. Am I missing something? Should I find another constant wire that I should hook up? Since the alpine that I am using is not powering on. Every fuse is good far as I can tell.
I do recall when I had benched tested it, I had to use all three wires which included the blue/white wire which is the turn on lead. If my memory serves me correctly that is for an amp. I could be mistaken though, if I had to wire in this wire. Where would I wire it to?
The head unit its self is a Alpine 7292LS.
Old 05-16-2024 | 08:00 AM
Cusser's Avatar
The red switched wire to the stereo should tap into the "Meter" fuse; a tail light wire would only be powered when the lights are on.
The yellow always-powered wire to the stereo should tap into the "Room" fuse, which operates the dome lights.
You may have to run a separate ground wire from the stereo case to a bare metal attachment like a screw into the body.
Fuse tap:
Old 05-16-2024 | 08:35 AM
Anarchy99's Avatar
Ahh ok, that makes sense. Also I am running a ground wire off the head unit to the the bare body.
Ill check those two fuses once more. Also yellow wire? I thought it was blue/red?
Old 05-17-2024 | 12:01 AM
MeB2000's Avatar
Read what Cusser posted again........"The yellow always-powered wire to the stereo" .........He is talking about the yellow wire that came on your Alpine stereo.
Old 05-17-2024 | 07:38 AM
Cusser's Avatar
Yes, and the Alpine stereo typically has a RED wire for switched power. These two wires typically contain an in-line fuse.
Old 05-17-2024 | 10:54 PM
Anarchy99's Avatar
Ah, my mistake then. I've never used fuse taps before nor wired them in at all. How would I got about wiring in the style that cusser has posted?
I've also checked the fuses on the alpine head unit, they looked good but I have replaced them for good measure.
Old 05-18-2024 | 07:42 AM
Cusser's Avatar
Originally Posted by Anarchy99
Ah, my mistake then. I've never used fuse taps before nor wired them in at all. How would I got about wiring in the style that cusser has posted?.
Fuse tap:
The left side of the fuse tap shown goes into the "protected" side of the fuse location, with the fuse spade inserted into it to hold it in place. Your wire with a standard 1/4" female connector slides on the tab on the right side.
These are so folks don't cut wires and then try to use crimp-style butt connectors.
Old 05-18-2024 | 06:07 PM
Anarchy99's Avatar
Thank you, Cusser. Head unit works like a charm now.
Also the wiring after I cleaned it up.
Old 05-19-2024 | 08:05 AM
Cusser's Avatar
Great !!!
Monk would want the fuse numbers all pointing the same way.
Just joking !
meta4
03-25-2021 09:52 AM
theslumbythesea
02-10-2021 05:49 PM
jaimie08mazda3
01-31-2012 08:15 AM
tungul
02-20-2009 08:59 PM
justinsanders
06-24-2007 09:16 PM
Quick Reply: Mazda Wiring Issues
