no crank and no clutch
Old 01-24-2007 | 10:43 AM
jcrozier's Avatar
Default no crank and no clutch
Hello all,
New guy here so be kind.
Old family truck(86 B2000),trying to get running again. Sitting for two years.
Was running fine 2 years ago.
Issue #1 - Clutch -Now noticed clutch goes to floor with no resistance and stays there.
Issue #2 - No crank - I can pour some gas in the carb. and she will fire up and run for about 5 -10 seconds and then shuts off. Obviously a fuel flow problem.
Can anyone out there offer a few tips? Thanks Joe
Old 01-25-2007 | 01:18 AM
wrecks74's Avatar
Default RE: no crank and no clutch
clean your fuel tank and fuel lines, change filters. you might have to take your carb apart and clean it also. as for your clutch, add some dot-3 brake fluid to the reservoir and bleed the system just like you do the brakes. theres a slave cylinder on the side of the bellhouseing. it will take two people. if you can't get any pedal then you'll have to replace the clutch master cylinder and/or the slave cylinder. hope this helps.
OziSpeed6
08-04-2013 11:27 AM
mazdaprotege97
12-24-2009 08:49 PM
PneumaticTire
12-26-2007 10:31 PM
Quick Reply: no crank and no clutch
