No Heat
No Heat
Hey - I have a B2600 with carb (did they come EFI?)
I didn't pay a lot for the truck, so I didn't pay a lot of attention to what worked and what didn't work either.
Anway...
The engine is not getting warmed up, and therefore I am not getting any heat in the cab. I already replaced the thermostat, and that didn't help. The heater blower works, but only tepid air comes out. The temp gauge on the dash moves only slightly from a cold start to operating temp.
Any help on what might be the problem would be greatly appreciated. I really don't want to spend a lot on this truck, so I am hoping it is something simple.
Thanks
Anway...
Thanks
RE: No Heat
After the engine warms up, does the upper radiator hose get hot? Generally, if you can only hold the hose for about 2-3 seconds, its about 180 degrees. If you can grab it and hold on for a long period of time, it is about 120-130 degees. If it is hot, are your heater hoses getting hot on both sides? What degree thermostat did you go with, and what brand? Just asking because i put an Autozone thermostat in my 323 and it opened way to early and same problem no heat. So I went to put in a Stant brand, and I had heat.
RE: No Heat
I will have to check the brand. I bought it at NAPA.
The top hose gets hot. I can only touch it for about a second. I will check the heater hoses. I guess I better get a Chiltons because I don't know where they are or what they look like.
thanks so far.
thanks so far.
RE: No Heat
Sounds like the engine is at normal operating temp. It could possibly be a bad heater control valve or a plugged heater core itself. I have also seen people bypass the heater core if it leaks also. Never know what you will find with a used car!
RE: No Heat
is it true that the heater core is buried under the dash? Thats going to suck if it is true.... I don't know if I have the time or hutspa to deal with that.
Do you know where the gauge sensor unit is in relation to the heater core? I guess what is puzzling me is that the engine does seem to get hot, but the gauge only moves slightly. I am wondering if the sensor is somewhere closer to the heater core where it might be behind the blockage????
RE: No Heat
The heater core is located in the air handler box behind the dash. IF the heater core is blocked, what I have done is to remove the heater hoses and connect a garden hose to clear it out.
Do you mean the sensor for the temp gauge? I just didn't quite undertand most of the last paragraph, and what you were trying to ask. The temp sensor is on the cylinder head near the thermostat housing. Should have a one wire connector and be about a 14mm wrench size. As far as a possible blockage, I speak of inside the heater core itself. If you have never seen a heater core, it looks like a miniature radiator. can become plugged internally. I would be sure to check the heater control valve which is inline of the heater hoses.
RE: No Heat
Hey bkey71 - I appreciate your trying to help out. I am giving up and will be taking it to a shop... I don't have the time or knowledge to deal with this one.
I will post afterwards and let you know what all it ended up being.
RE: No Heat
Either way though its probably best for an inexperienced person to just take it to a shop.
