Picked up a clean 89 for $250
Old 03-20-2017 | 09:05 AM
frenchsquared's Avatar
Default Picked up a clean 89 for $250
Found this rather clean 1989 B2200 for $250. Seller said the engine was bad. I don't think it is. No knock, no ping but it shakes violently. Has a really bad miss. After work today I will spend some more time figuring out what its not firing. Might get luck and it will be something simple like a bad plug or wire.
Old 03-20-2017 | 01:19 PM
Does anyone know if someone makes motor mounts to put a SBC in a B2200?
Old 03-21-2017 | 07:56 AM
Cusser's Avatar
Great find. Check compression, plug wires, distributor cap, vacuum leaks, EGR stuck partially open.
Old 03-21-2017 | 08:14 AM
Found this laying on the power steering pump and behind the header. Block has a hole in it the size of my hand. Time for an engine swap.
theborland
02-06-2014 05:04 PM
DN27
03-24-2008 08:14 PM
voomx3
04-02-2007 01:04 AM
guitar73
07-30-2006 02:22 PM
Quick Reply: Picked up a clean 89 for $250
