power steering pressure line
I see that the rubber portion is available new for 30-40 bucks so no problem there. What about the metal line portion that comes directly from the pump to the hose? If I have some corrosion that is beginning to seep, how do I contend with that? Are there retro fits with parts from other vehicles or am I stuck sourcing from salvage vehicles? What are any options?
Thanks, John
Thanks, John
Thanks, John
Thanks, John
If so, this part appears to be available from Mazda dealers or online as Mazda UB4032617 about $50-$60
UB4032617.html
I'm 99% sure I have a used banjo/steel linein a box in my 130F garage 100 miles away in Phoenix, as I purchased a used power steering gearbox for my own truck a decade ago, and pretty sure I grabbed that part. It would cost almost as much from me as a new part with shipping.
Somehow I get the feeling that your truck would be out-of-service a couple of days if you took the steel pipe off and tried to clean it and solder/braze to repair it (or have a machine shop/radiator shop do that), so you want to have a replacement on-hand for a simple part exchange. You'd need two new copper crush washers for the banjo fitting too.
Parts oftentimes don't come with needed parts like copper crush washers. I found this out last year when I replaced the flexible brake lines on the front of my B2200. I bought a copper crush washer kit from local Harbor Freight and used that.
Local parts stores had bubble packs of copper crush washers, usually in the oil change parts area, but those were way more expensive.
