Rear Brake Help
Old 10-15-2023 | 01:14 PM
Mickey12's Avatar
Default Rear Brake Help
Help. Doing a rear brake job on a 1999 Mazda B3000, 10” shoes. Unable to put new drums on because the shoes spread out at the top when I replace the long spring across the bottom. Too tight a fit. What I am I doing wrong.
Shoes spread out at top post
Old 10-16-2023 | 06:36 AM
Have you made sure the adjuster is completely undone?
Old 10-17-2023 | 09:36 AM
Mickey12's Avatar
Thanks for the response. I think I have a bigger mess. Mazda Brakes B3000 1999 Duo-Servo brakes, I assume? Unable to place new drum on new rear shoes. I’ve discovered that there should be a front primary shoe and a secondary back shoe on each wheel. I think I installed them backwards. However, the pin that holds the e-brake cable is attached to the primary shoe which is now on the secondary (back) position. Is this assumption correct? Can I remove and replace the pin and install it on the on the secondary shoe once I flip them correctly? So I then have a larger front primary shoe and a smaller secondary back shoe? Photos are of the passenger’s side of vehicle.
frypod
04-07-2024 10:41 AM
Geo-B
04-29-2020 04:25 AM
omnip0tent
06-22-2018 01:18 PM
Burkhart
04-20-2007 04:56 PM
mainman2c
07-21-2005 02:19 AM
Quick Reply: Rear Brake Help
