removing freewheel hub bolts-help!
Old 04-13-2008, 09:24 AM
flourdude's Avatar
Default RE: removing freewheel hub bolts-help!
Agree, and I have previously pounded the 3\8 (both 6pt and 12pt) on and it slips off .The metal of the bolt is soft which has also made it difficult.
Thanks for the suggestions though, I wish I could report success with them!
Old 04-14-2008, 08:28 PM
cochleardad's Avatar
yes i agree with the 3/8 theorey because it sounds like rust has shrunk the bolt, remember if all else fails use a damage bolt remover which is designed to tighten up on the bolt as you loosen it you can get a set for about 20 dollars just remember not to use a impact but use a large wrachet or a johnson bar and i garauntee you'll get those bolts out.
Old 04-15-2008, 06:06 PM
yes good reply, a snipe and a socket wrench is a good idea.
Old 04-29-2008, 04:37 PM
You did not mention in you post if you have put a torch on them. Heat will loosen up rust and lock tight.
Old 04-30-2008, 10:25 AM
mxer201's Avatar
ORIGINAL: kdf68
Ditto that. Let me add after carefully heating the bolt press an ice cube against it for a few seconds. This rapid cooling should make the bolt contract just enough so you canbreak themloose. The first time I removed the heat shield from the exhaust manifold on my 91 B2600i I just knew those small bolts would twist and break. After getting the motor to normal operating temp Iheld an ice cubeagainst each bolt. Glad to say I was able to loosen all the bolts. Afterwards applied antiseize to the threads. Good luck.
Old 04-30-2008, 11:02 AM
working with heat gotta be carfull obviously of melting seals and gaskets and such. I dont know how those hubs are put together but know before applying heat.
Old 04-30-2008, 11:11 AM
mxer201's Avatar
ORIGINAL: tnerb
Exactly right. I thought about adding to the post wrapping a wet rag around the hub to protect it. And to very carefully apply the heat to the head of the bolt only. May want to look at an exploded view of the hub before proceeding.
onekrissy1
04-26-2013 12:42 PM
Paul DD
09-25-2012 12:07 PM
smearnoff5100
01-10-2011 10:56 AM
woodnic
02-06-2007 04:19 PM
fourbanger
11-11-2005 08:23 PM
Quick Reply: removing freewheel hub bolts-help!
