Rocker arm removal
Old 04-22-2008 | 06:50 PM
rlhast1959's Avatar
Default Rocker arm removal
Bought a 89 B2200 from a friend, just fixing it up. I want to replace the valve stem seals, but ran into a small problem. There's a bolt behind cam pully that keeps the rocker's from being removed. Can't get a socket in through the hole in the cam pully, is there a way to get the bolt loose without removing the cam pully or is there a special tool to reach through the hole to get to the bolt or can the rocker's be removed with removing this bolt.
Old 04-24-2008 | 10:30 PM
toddluck's Avatar
Default RE: Rocker arm removal
gotta pull it
Dion Greenfield
03-30-2013 01:15 PM
malekogirl
06-15-2011 02:39 PM
sven
05-08-2011 09:43 PM
krazykarpet
05-11-2009 04:34 PM
mazda5momma
07-05-2007 02:32 PM
Quick Reply: Rocker arm removal
