Rough idle b2200
Old 05-05-2022 | 12:25 PM
s45607e's Avatar
Default Rough idle b2200
I change spark plugs and wires rotor button and cap and gap the spark plugs. It wasn’t idling rough before I change wires and plugs. Any suggestions?
Old 05-05-2022 | 09:01 PM
Cusser's Avatar
Suggestion : this was caused by something you did !!!! Just why did you make these changes?
Did you change the spark wires ONE AT A TIME ????
DID YOU CHECK THE GAP ON THE SPARK PLUGS ??? 0.028 - 0.033 inches
Are the wires pushed FIRMLY onto the spark plug ends? And firmly into the distributor cap? Did the new rotor and distributor cap visually look identical to the existing ones?
Change the rotor back to original, see if any difference.
Change the cap back to original, see if any difference.
Old 05-06-2022 | 08:15 AM
Cusser's Avatar
Did you knock off or break a vacuum hose?
Weber carburetor or factory one?
Anything else you did and didn't include in your post?
Old 05-06-2022 | 01:20 PM
s45607e's Avatar
  • Changed wires one at a time
  • .032 spark plug gap
  • checked wires and cap and rotor button
  • factory carb
  • I will check vac hoses and switch back original cap/rotor to see if there is a difference
Old 05-06-2022 | 08:36 PM
The Lizard King's Avatar
  • factory carb
Did you PM anyone else about this problem of yours like you did me?
ansheehan83
10-16-2021 10:03 AM
mhopkins
08-28-2011 08:26 AM
BettermanNZ
08-14-2007 07:59 PM
isl_cruiser
07-19-2006 12:39 AM
neeltampa
10-03-2005 09:25 PM
Quick Reply: Rough idle b2200
