Stalling Truck
Old 09-09-2013 | 11:14 AM
Hooklip's Avatar
Default Stalling Truck
I have a 1992 Mazda B2600I 4X4 with 140,000 miles. The trouble I am having is it will run for about 30 minutes then stall and wont start again till about 30 more minutes then it will do the same thing. I tested it and it stops firing. Did notice a click sound when I just turn the ignition switch long enough to bump the starter, when this happens it will start. Sounds like the click is coming from the box right above the fuel pump relay. Does anyone know what this might be?
Old 09-11-2013 | 12:05 PM
Hooklip's Avatar
Anyone? Any Idea?
Old 09-16-2013 | 09:29 AM
Hooklip's Avatar
I guess no one knows what it is...LOL!!
Old 09-16-2013 | 09:55 AM
tanprotege's Avatar
I don't know about the clicks. But did you check the ignition parts yet?
Old 09-16-2013 | 10:13 AM
Hooklip's Avatar
I put a new coil on it. Like I said if the thing above the fuel pump relay clicks it will start.
Must be some kind of relay.
Old 09-16-2013 | 01:57 PM
tanprotege's Avatar
Well, replace it.
Another thought: if the ignition switch at the column is on the fritz it could possibly turn the relay off: lets say the contact at the switch gets hot then bends and opens---no more spark and fuel! Once it cools off it works again.
I am not saying that's what's happening, but it is something to look at.
skiya67
12-18-2005 11:33 PM
flyby
11-08-2005 10:48 PM
Trivek
10-26-2005 03:57 PM
mazda_truck
08-08-2005 12:43 AM
fakefire
07-09-2005 11:55 PM
Quick Reply: Stalling Truck
