Starting problems on BT50 2007 2.5 diesel
Old 09-23-2019 | 05:02 AM
nasa's Avatar
Unhappy Starting problems on BT50 2007 2.5 diesel
2007 Mazda BT 50 2.5 liter diesel manual wont start but fires up with arostart and runs perfectly have tested glow plugs and replaced crank sensor it dosent matter hot or cold it wont start without arostart but then will run faultlessly all day.
Because while cranking it if I hit it with arestart it will start I though glow plugs, So after testing the glow plugs I hot wired them directly with 12 volts and held them for 20 seconds and while cranking but still no go so I figger it cant be the glow plugs. I then went for the fuel but if i squirt it with arostart it starts and then runs perfectly at all reves , it will run all day without fault, So I tried replacing the crank sensor and that made no difference whatsoever. This thing is driving me crazy I just cant figger out what the fault can be. It sorta points to fuel but once it fires there is no fuel problem whatsoever.I have checked fuel lines and filters ect. We have tried anouther starter that we new works although the original is spinning it over very well. Compression is OK as I say it runs fine once started. I am now at my wits end with it. Has anyone any idea where I can look next.
Old 09-23-2019 | 05:18 AM
Common problem with electromagnetic interference from the starter motor upsetting either the crank or cam sensor. You need to scope both sensors to check/inspect clean clear signal to the PCM or view live data for RPM on cranking ( will show an erratic RPM signal )
New starter motor is the fix, if it is the case.
Old 12-26-2020 | 03:10 PM
Shorvei's Avatar
I have the same car with the same problem as described above.
Does anyone have a solution for this problem?
I’m verry grateful if someone can give me any tips.
Old 12-27-2020 | 05:51 AM
Have you scoped the cam & crank sensors? Do you have a clean signal?
Old 04-22-2021 | 08:57 PM
Scruffydogg's Avatar
I have a 2009 3.0 litre and it has the same issue, struggle start morning and afternoon after I finish work.
Old 03-23-2022 | 05:53 AM
jordzselv3's Avatar
Same issue 2007 mazda bt 50
The longer I drive it the harder it is to start
but will still take a extra extra crank or two in the morning
I must resolve this issue
Old 06-18-2024 | 09:57 PM
randalcanning@bigpond.com's Avatar
Default Electromagnetic issue with starter motor
Howdy
I have a BT50 2010 model, 3 litre diesel.100000km.
Started the Journey 3 years ago.
starting issue got worst gradually, had to turn it over for a while to get it to start.
Replaced fuel filter, injectors serviced, glow plugs replaced and new optima 975 CCA battery.
not much changed.
Then eventually would not start.
Mazda investigate and said it needs a new crank angle sensor, replaced crank angle sensor with no success.
Then said ECU needs replacing, quote $4000? Stop there.
Sent it to a diesel performance place, they replaced the starter motor and was good for 13 months and same related issue.12 months out of warranty and refund on repair cost.
Tried another mechanic and he found out the starter motor should be a upgraded model to stop the electromagnetic issue causing the crank angle sensor fault.
Fitted a new starter motor and 12 months down the track same issue again.
The mechanic fitted another heavy duty starter motor that I should not have any issues with.
And now again 12 months down the track having troubles starting.
The engine is cranking well and good battery voltage.
Any tips would be great before going back to the mechanic again.
Also I purchased OBD11 reading and P0335 crank angle sensor fault is coming up again.
JimNQ
12-12-2019 12:18 AM
Nick123
01-12-2012 07:07 AM
subyted555
10-22-2011 01:28 PM
Alister
10-12-2010 06:51 PM
r.hewko@krusena
06-12-2010 09:42 AM
Quick Reply: Starting problems on BT50 2007 2.5 diesel
