Throttle freeplay 1984 B2000
Any ideas on how to fix the problem of freeplay in the linkage on a 1984 B2000? The piece that is attached to the firewall, with the linkage coming through has a lot of freeplay. It is causing a good 3-4in of play at the pedal with a grommet filling the gap. I will post a picture when I can next weekend if it is needed.
Any thoughts on how to convert it to a throttle cable?
Would it be easier to do a Weber or Holley conversion?
If that would be easier, what Weber would be recommended?
http://www.webercarbsdirect.com/Carburetors_s/2.htm
http://pa.partsandaccessories.com/pa...uretor&dp=true
RE: Throttle freeplay 1984 B2000
here's some pics of the pedal assembly and adjusting nuts at the carb
(1)check the pedal arm it might be bend if the adjustment nuts dont help
the pedal linkage pic looks the same as my 91 b2600
ORIGINAL: mazdab2600
Pappa T
06-16-2006 05:44 PM
