truck shutting down
Old 12-22-2006, 08:10 PM
1owner's Avatar
Default truck shutting down
Greetings & happy holidays to all.
I have a problem w/ my 91 B2200 that hopefully can be diagnosed by someone on this site.
Today, while attempting to accelerate from a stop warm, the truck "stumbled", then caught. It proceeded to quit running a few times when decelerating// coasting under 1200 revs, but would restart with little trouble. After sitting awhile, I started her up and she wouldn't run between 500-1100 revs. Anything over 1500was fine. Changed the plugs, started her up and she quit running after 10 minutes on her own. Tried again w/ same results. 170K on the clock. Automatic trans. Any help appreciated as I love this thing to death.
Old 12-23-2006, 06:00 PM
1owner's Avatar
Default RE: truck shutting down
Solved myself. Sediment in tank.
Old 12-29-2006, 03:58 PM
Thanks for your post 1owner. You may have answered the problem I have been having. I will check that out on my 1990 B2200. I only have about 2500 milles on my rebuild.
Old 01-02-2007, 03:04 PM
1owner's Avatar
Still doing the same thing intermitantly. Could it be some deceleration device?
Old 01-02-2007, 07:34 PM
did you replace all filters?
youll also need to flush out the lines
Old 01-03-2007, 02:23 AM
1owner's Avatar
I think there's only one fuel filter on this truck - right at the gas tank. I'm not sure how you flush the lines on it. Any detailed info would be appreciated. B.t.w.- Could the idle circuit have dirt lodged in it?
Old 01-03-2007, 04:26 AM
on my 86 and on my 89 there is a canister on the passenger side firewall
Old 01-07-2007, 07:20 PM
1owner's Avatar
Still trying to diagnose...
Old 01-07-2007, 10:55 PM
to flush disconnect the line at both ends, and flush with gas, go from the engine back, with gravity, catch all the fluid to see what comes out. did you look for the filter on the passenger side firewall?
Quick Reply: truck shutting down
