Trying to die when in reverse...
I have a 2000Mazda B4000. Recently has started to try to die when put in reverse. Will run very rough when backing out of drive, and will die if go very far in reverse. Any ideas where to start.....?
tom...
tom...
RE: Trying to die when in reverse...
Check and make sure the intake air tube between the air cleaner housing and engine is not torn open. This is the flexible black rubber part. Engine torque twists the drivetrain in a different direction between forward and reverse gears and is maybe opening up a tear only in reverse and allowing unmetered air into the engine.
kongquistador
08-04-2013 05:22 PM
