Turn fan speed up, A/C compressor shuts off!
Old 08-28-2010, 10:44 AM
oOBlackHandOo's Avatar
Default Blower Motor Resistor
I just got one at autozone. 44 bucks tax and all. Parked under the shade tree and took about 5 minutes to remove the glove box and install it..... SO SWEET!
Here's the link to the one for my 90 b2200 SE http://www.autozone.com/autozone/par...382&store=3850
Old 10-14-2010, 06:55 PM
62687's Avatar
Default 87 mazda 626 blower motworking
blower not working on setting 234 works on setting 1 have replaced resistor and blower motor still not working
Old 12-11-2018, 07:24 PM
Sharon Hunter's Avatar
Default cusser,95414
Originally Posted by Cusser
There's a resistor pack under the dash, attached to the evaporator box.
I posted this above.
i have a similiar problem but worse.when i cut my fan swich to 1.to use ac or heat even to turn my defrost on .my car shuts off an makes a noise.what could be my problem
Old 12-12-2018, 08:46 AM
Cusser's Avatar
That sounds like the AC compressor is seized, and the resistance makes a terrible sound and can even cause the engine to stop. The AC compressor normally comes on in the defrost position as well. For a short term "fix" to get the truck running for winter, cut off the AC belt or do not turn on either defroster or AC.
Same thing happened to my 2004 Frontier in September on way to California; I just turned off AC, replaced the compressor and drier once I returned.
Old 08-26-2024, 11:05 AM
gregorgreg's Avatar
i have a similar issue, ac light comes on but not compressor or radiator fan. fuses and relays are good. i can manually turn both of them on with a scanner but if i turn the compressor on, the fan does not turn on with it. i think its either going to be the controller or the pcm. i dont know how to confirm that besides testing wires. i guess it could also be something to do with the fan module but from what ive seen on the schematic, i dont see how it would affect the compressor turning on. any advice is appreciated.
Old 08-26-2024, 04:51 PM
MeB2000's Avatar
So......what year and model vehicle do you have?
Old 08-27-2024, 08:31 AM
Cusser's Avatar
Sounds like a 1994/newer made-in-USA Mazda/Ford Ranger to me.
On "our" 1986-1993 made-in-Japan B-Series Mazda trucks, such symptoms would be consistent with a bad blower resistor.
the dude 1313
04-08-2008 12:41 PM
veerent
03-18-2008 07:12 PM
jennwutok
11-23-2007 08:00 PM
jboogyrockdamic
03-19-2007 12:19 PM
Quick Reply: Turn fan speed up, A/C compressor shuts off!
