Vacuum leak?
Vacuum leak?
I'm wondering if I have a vacuum leak ... I have an 88 mazda b2200 which shakes a bit when idling. Seems to shake a bit more when in gear and idling as opposed to put in neutral (it's an automatic transmission). Does that sound like a vacuum issue - or something else?
I also failed an emissions test recently which apparently could also be vacuum related.
If it does sound like a vacuum leak problem, are there any relatively easy ways to check where the leak is coming from?
RE: Vacuum leak?
to hear it you would listen for a hissing noise and to feel it you look for open hoses or feel and follow hoses it see if any are disconected the feel of an open hose if it has vacuum on it is it will stick t oyour finger or of course you will feel air if you are close to it
sherrid36
06-13-2008 11:19 AM
