valve cover question
Old 03-31-2008 | 08:43 PM
jcody's Avatar
Default valve cover question
Hey guys, does anyone know what the torque value should be of the valve cover? i have a torque wrench and everything just need to know how tight it needs to be. thanks
'89 b2200
Old 04-03-2008 | 07:53 PM
cochleardad's Avatar
Default RE: valve cover question
if you have a haynes or chiltons book it would tell you exactly the value but it is usually about 10 foot pounds or 120 inch pounds depend on your torque wrench
Old 04-09-2008 | 11:51 PM
dsadosky's Avatar
I just replaced mine and torqed them to about 5 ft lbs. After 500 miles no leaks. Make sure that the bolt threads and bolt holes are clean and that the bolts thead easily. Also a thin coat of red or blue sealer across the front and rear cam journals helps. Note do not allow the sealer to enter the bolt holes.
cugene
05-09-2007 09:49 PM
blueblazes
04-25-2007 02:54 PM
bjt2926
08-21-2006 10:30 PM
stace
07-05-2006 10:00 PM
keninn
09-03-2005 02:17 AM
