Weber install now AC wont kick on
Old 04-20-2021 | 03:37 PM
90-B2200's Avatar
Old 04-20-2021 | 04:47 PM
90-B2200's Avatar
The internals of the switch were not dirty. The problem was loss of continuity between one of the contact blades and the solder post. I re-soldered and now the switch works.
dinner break....
then I’ll put it back in the truck and real time test.
Old 04-20-2021 | 08:11 PM
90-B2200's Avatar
Switch back in truck and system works. Im waiting for warmer weather to put it through some real testing
Old 04-21-2021 | 08:33 AM
Cusser's Avatar
Originally Posted by 90-B2200
Fantastic information Cusser. I’ll try and repair this switch. Thanks again!
Sounds positive !!!
I bought my '88 B2200 in August 1994 with a bad compressor. I replaced the compressor myself, maybe a year later I had an issue with the AC push-in switch. I remember pulling the switch rearward (both wire harnesses still attached) and cleaning it in place, in the truck cab. That's the switch that's still working in my truck.
The other switches I'd fixed and sold I did on the bench. Glove box had to be removed to pull those at the parts yard. Mr. Ohmmeter was needed to confirm repair.
Old 05-02-2021 | 01:52 PM
90-B2200's Avatar
Nice 80 degree day here so I finally got around to charging the ac. Started with weak performance of only a 10 degree drop from ambient to 70 degree. After charging I’m getting 40 degrees at the vent in recirculating cab air with windows closed and 50 degrees at vent pulling 80 degree ambient fresh air. I’m satisfied.
Old 05-03-2021 | 08:11 AM
Cusser's Avatar
That's real good, and will be better once the truck is actually moving. Congratulations.
Remember: if the refrigerant does leak out over time: fix the leak, never add any sealant or refrigerant containing sealants !!!
Old 05-03-2021 | 08:27 AM
90-B2200's Avatar
Where is the condensate drain on these trucks? I need to get at it and make sure it’s clean.
Old 05-03-2021 | 08:32 AM
The Lizard King's Avatar
Under the dash on the passenger side. There's a rubber hose that goes through the firewall that drains the water to the outside.
Old 05-03-2021 | 10:05 AM
90-B2200's Avatar
got it thanks
rujoesmith
09-15-2021 06:48 AM
Budgy
03-26-2020 06:29 PM
webbcraft2150
04-22-2019 09:10 AM
Keyser
08-04-2006 06:00 PM
colmax
06-12-2005 03:50 AM
Quick Reply: Weber install now AC wont kick on
