Push Button Start Malfunction
Old 06-25-2021 | 09:15 AM
shl615's Avatar
Originally Posted by Steve Grant
i purchased a small faraday bag esp made for key fobs, on amazon.
I keep the key in the closed bag in the car in my garage when not in use. This cuts all communication with the key fob and the car. So far i have not had any low battery warnings so i say it is working
Thanks for the quick response! Is there a reason why you keep it inside the car?
Old 06-25-2021 | 12:37 PM
Steve Grant's Avatar
i always know where it is, my garage is secure. I tried keeping the key in the house but it still communicated with the car and depleted the battery. Faraday bag prohibits that
Old 06-25-2021 | 01:13 PM
shl615's Avatar
Gotcha gotcha, I understood the faraday bag functions, but I was wondering if you keeping it in the car also was a part of solution. Since the faraday bag will also work in the house, the position of the key isn't relevant, right?
Old 06-25-2021 | 10:10 PM
correct
Old 12-24-2022 | 01:07 AM
RAGE's Avatar
Originally Posted by seoulight
I just had this happen to my 2019 Mazda3.
Unlocked the car normally and when trying to turn it on, received an error that there was a push button start malfunction. Tried both key fobs. Tried everything the dealer service suggested. No luck. I wasn't even able to lock/unlock the door or trunk. Service suggested I have it towed to them but it was late in the evening and I'm hardheaded and thought I could figure it out.
Searched online and decided to try jumping the battery. Worked. Drove the car around and turned it off. Wouldn't turn on again. Tried a few more times and had luck. It turned on but got an error that there was a critical charging failure.
Decided to take it to Advance Auto for a new battery.
Works perfectly so far. Still plan on taking it to the mechanic for a checkup but figured this might help someone with the same issue.
Thank you to everyone in this thread who had advice.
is your vehicle having issues after replacing the battery?
Old 04-17-2023 | 10:23 PM
Sasou's Avatar
Default The solution is simple
Solving it is very simple
Press the power button twice without pressing the brakes
Put the car on N
Then press the brake and press the power button
In some cases you may notice movement in gearbox
Although the spar on N mode does not be afraid.
After you start the car you may notice that the warning message is gone
Tell me what happens with you after trying this solution.
Old 01-30-2024 | 09:58 AM
Marnix's Avatar
Put the car on N
I tried your advice but unfortunately it didn’t work. Was not able to shift to N. Seems to be completely stuck
gleninaz
09-16-2019 02:16 PM
etsok1
05-16-2019 11:24 AM
Mark Fleet
02-10-2019 01:48 AM
Bashar faris
05-20-2018 06:46 AM
dewviking
11-14-2006 11:20 PM
