17" wheel on 2019 CX-5 GTR?
Old 06-10-2019 | 03:03 PM
MClogger's Avatar
Default 17" wheel on 2019 CX-5 GTR?
Has anyone installed 17" wheels on a 2019 CX-5 GTR? I want to be able to put some 17" snow tires on my wife's new GTR, but I haven't been able to determine whether a 17" wheel will fit over the brakes.
Old 06-11-2019 | 08:17 AM
Have a look at your spare tyre and see what size that is, might be 17".
Old 06-11-2019 | 06:52 PM
MClogger's Avatar
I had not thought about that and I did check. It is a space saver tire sized 145/90x16. So super narrow and tall and probably not enough wheel barrel to be a valid test. But thanks for the idea.
Old 06-12-2019 | 06:14 AM
If a 16" rim fits, then that guarantees a 17" rim will also fit. Look for a cheap set of factory 17" Mazda alloys for sale. They will have similar or exact offset as well.
Old 07-11-2019 | 10:42 PM
spchin24's Avatar
I am also curious about this. I reached out to my local dealer to see if they knew whether 17s would fit with the larger brakes on the CX-5 GTR, and they did not think that they would.
I don't know if that's true if the 16" is the spare. Generally those won't have to cover the brake caliper completely right?
Old 07-12-2019 | 09:18 AM
mazdaCPA's Avatar
I have relied on TireRack in the past to tell me what will work. They do say that 17" wheels will work on the CX-5 GTR. They don't list any 16".
Are the brakes the same on all CX-5s? If so, I would be comfortable assuming a 17" will work on the GTR if it is standard on the lower trims.
Old 07-12-2019 | 01:19 PM
spchin24's Avatar
The front brakes on the Reserve and Signature are slightly larger.
From Mazda's site: https://www.mazdausa.com/vehicles/cx-5/specs
Sport, Touring, and Grand Touring trim
Brakes 4-wheel disc, diagonal hydraulic
- Front 11.7-inch vented disc
- Rear 11.9-inch solid disc
Reserve and Signature trim
- Front 12.6-inch vented disc
Old 07-12-2019 | 01:57 PM
mazdaCPA's Avatar
That could explain why TireRack says you can downsize to 16 on the sport but only to 17 on the GTR.
Old 07-13-2019 | 10:21 PM
spchin24's Avatar
Good catch, I think I'll trust TireRack and if they don't fit then I'll return them.
Old 08-15-2019 | 12:12 AM
Litehiker's Avatar
When I had a 2007 RAV 4 V6 I bought steel wheels 1" smaller size than factory and put All Terrain tires on them for winter use. All Terrain tires look like winter tires but last a lot longer and do almost as well. I drive lot in the desert southwest, mostly on dry pavement, so need that extra wear.
Now when I buy my new 2019 CX 5 I'll do the same.
Eric B.
Spunky79
05-13-2019 04:55 PM
Ymee
12-28-2017 01:11 AM
mmitsch
07-02-2017 04:54 PM
bOLsAK3
05-21-2012 04:31 PM
mzd3_stratblu
05-18-2006 02:04 AM
