2015 CX-5 transmission service needed?
2015 Cx-5, 157k miles. Running fine. Does the transmission need service at all at this mileage? I've heard it's a lifetime, no need to thing..
If it's needed, can a good mechanic do it or should I go to a Mazda service/dealership? (The Mazda dealership I usually used, I think, has changed hands and seems to be more greedy on wanting that dollar!)
Start with a basic pan filter and oil change. From there when they drop the pan you will get a good indication of the state of health of the transmission by what is found and what the valve body and pan looks like.
The service is very simple and most service shops should be able to do this. However it would be better to try to find a service shop that advertises Transmission servicing as they are better experienced to know what they are finding when the pan is dropped.
You are defiantly over due for the basic service!
LIFETIME means when the warranty is over....
Can a trust a good local mechanic?
Oil analysis I have had done with many automatic transmissions with so called lifetime no service have all shown that had the oil not been changed there may have been problems caused by none serving. My own 2018 Mazda I have done the service several times and started a oil analysis that shows from the first things in the fluid that would have caused a varnish to start to form and build up over time. I have posted empirical data in the form of oil analysis as well have shown pictures a few times of the service on my MADA in my thread.
On customer vehicles it is the same results, when they waited it first of all took a few servicing to get the fluid to run clear again or I had to do a complete fluid replacement.
On your MAZDA the service should only be about 1.5 hours labor plus the oil and filter and gasket(if they choose to use one)
ASE
I am going to assume based on those answer that they are simply reading that the auto manufacture states lifetime fluid or no service for lifetime? sad!
ASE
ASE
