2021 CX-5 GTR Oil Filter
Old 12-04-2021 | 12:07 PM
Dennis Wendt's Avatar
High performance oil filters are designed for oil flow at the sacrifice of efficient filtration. They also tend to be larger in size.
Old 12-04-2021 | 12:49 PM
Sojourner55's Avatar
Denis....Fram UG7313 will work for the 2021 GTR ??
Old 12-04-2021 | 12:50 PM
....sorry....7317....apologies
Old 12-04-2021 | 01:47 PM
Yes it fits fine. Doesn't contact the plastic cover.
The older (these days) 3593A is fatter but not as tall as the 7317. Not sure of
that one would fit.
Autos that USED to be spec'd for the 3593A are now listed with the 7317.
Easier to find.
My 2¢
Old 12-04-2021 | 04:44 PM
reubenvabner's Avatar
While you Gentlemen are on this subject, may I ask if there are any opinions among you on the EZ Drain Valve? Or the Fumoto? Or any such device?
Also, I assume the CX-5 comes std (haven't looked yet) with the auto trans pan with no drain hole and plug. Any reason I should NOT install an aftermarket pan WITH
a drain built in?
Thank you, Reuben
Old 12-04-2021 | 04:51 PM
IMHO and recommendation DO NOT USE those valves. It is bad enough that almost ALL oil pans because of the bung weld will accumulate oil that cannot be drained. Stay with conventional drain plugs. In fact I highly recommend the use of a DIMPLE DRAIN PLUG
Old 12-04-2021 | 04:56 PM
Not really.....
If needed I can split the case so you can see the inside?
Just request and I will oblige!
Old 12-04-2021 | 04:58 PM
a drain built in?
Thank you, Reuben
Did you look at my thread?
Mazda3 Things I like to do - Mazda Forum - Mazda Enthusiast Forums
Old 12-04-2021 | 05:11 PM
Unless they changed it lately, Mazda has drain plugs on their transmissions.
Old 12-04-2021 | 07:08 PM
I've used the Femco system for many years going back to my '94 Z-28. Much less mess when draining old oil. This is currently on my '16 Ram and '04 Malibu. The Fumoto sticks out too much from my opinion and was always afraid of it tearing off if I accidentally ran over something.
Quick Reply: 2021 CX-5 GTR Oil Filter
