Anyone having any troubles with the Keyfob?
Old 04-13-2022 | 09:28 AM
Glund's Avatar
Default Anyone having any troubles with the Keyfob?
I bought a new CX-5 in 2021. Almost immediately, the key started giving me the low battery warning. I switched to the other key, same thing; it worked for a couple of months, then started giving the same message. Switched batteries, exact same scenario. Most recently I replaced the battery less than a week ago and it's already giving the same message.
Since the issue has occurred with both of the dealer-provided keys and by now about 5-6 different batteries, the battery is not likely the issue. Has anyone experienced similar problems, and is there anything I can do about it besides replacing the battery every two days?
Old 04-14-2022 | 06:58 AM
kaehlin's Avatar
That sounds very frustrating. I have had no problems with my 2022, but only 600 miles so far.
Old 04-14-2022 | 07:43 AM
chickdr19's Avatar
Sounds like a trip to the dealer is in order. This is not typical behavior. My '21 has not had this happen with either fob in the 11 mths I have owned it.
Old 04-14-2022 | 01:16 PM
Grouch's Avatar
That sounds like corrosion in the battery connectors. My batteries recently wore out, after about 5 years, and replacement worked just fine.
Old 04-18-2022 | 03:37 AM
diehard888's Avatar
Well - if you are still within the first 12 month 12k Warranty " adjustment period " - You should be able to get Mazda to replace the Fobs and reprogram under full warranty - IF it has been definitively determined that they are defective for whatever reason ...and have been since you took delivery /. Even the 3/36 you might still have a case /
Do you have dealer visits with attempted trobuleshooting history and service history notes ? Staying with a good service writer that properly indicates the accurate history is imparitive on this request -
I sold Maz for years and have seen every scam in the book to get warranty stuff. ~ 2 Fobs with programming is likeky $750 -+ - Possible the fobs were dropped in the toilet by the salesperson in a hurry / or PDI service techs in a hurry ,,, then dried off and put in the books - seen it happen ( well I heard the story ) - try for warranty relacement
Old 04-18-2022 | 08:32 PM
jmartin's Avatar
My 2019 Mazda3 has the same flat keyfob. I am still on the same batteries with no problem. As others have said, take it back to the dealer. You should not be having these problems.
Old 04-20-2022 | 09:05 AM
Chris!'s Avatar
I've had my 2021 Signature for a year and I'm still using the original batteries. Something's up if you are going through them that quickly.
Old 04-20-2022 | 02:06 PM
BWJ's Avatar
BWJ
you remember to use CR2032 instead of CR2030 battery, -not ;-)
Old 04-23-2022 | 08:57 AM
Cohappy's Avatar
Default Similar issue
I am having a similar issue, I have had my car not quite 2 months and changed the battery once and it came up low battery again. when I changed the battery again I checked the old one and the old battery was fine, Any thoughts about this?
Old 04-23-2022 | 09:14 AM
chickdr19's Avatar
My 19 used to do that at times. Low battery would come up and the fib works risk fine afterwards. My 21 has yet to have the issue.
