Anyone know an easy way to fix this, and what it goes to?
Doesn't look like it in the pic, but the yellow wire is completely chewed in two.
I believe it's part of the EVAP system; called a purge control valve or purge solenoid. You should be able to splice it together even if you have to add a short length of wire to do so.
I do not recommend a splice repair. For any connectors that control information to the ECU use proper connectors only. If you need to lengthen any wires use the same color and size wires and then solder and shrink wrap the wires.
FindPigtails.com – Find Your Automotive Pigtail Connector in 30 Seconds or Less
