AutoDoor Lock
AutoDoor Lock
I'm having an issue with the auto door lock feature of my 2022 CX5. It's not a huge issue but it's an annoying one and it should be covered under warranty. Dealers have been zero help in addressing it. Basically the car is supposed to automatically lock when I close the door after turning off the ignition. This works about 95% of the time but it's the 5% that's an issue. Has anyone had a similar experience or know of a solution? I've been to two dealers who both say there is nothing wrong so they can't address it.
Thanks for the reply. As I mentioned this works 95% of the time. However 5% of the time I turn the vehicle off, exit (with the FOB in my pocket) and walk away only to get a notification that it hasn't locked and I need to either use the app or return to FOB range and lock it.
Given it's both FOB's and that the issues started pretty much as soon as I got the car new off the lot I doubt that's the problem. Having said that it's worth trying. Thanks for the advice I'll pick up some batteries
This is not an uncommon “issue”. Most of the time it is due to the driver walking away from the CX too rapidly. This happens to me when my wife exits the vehicle after I do and I am over 5-10 feet from the vehicle - it won’t lock. I just stay close to the CX until after my wife shuts the passenger door, then things work fine and the doors lock.
Yeah, I forgot that can happen, but I'm old and not that quick anymore.
Funny how "electronics" have changed us so much we find it too time consuming/annoying to simply press the FOB button to lock the doors.
If the TV remote had never been invented, I wonder how many stations there would actually be now
It's a very specific requirement for it to work.
If you are not within fob range after all doors and the hatch are closed and don't hear that first beep, it won't beep again and autolock when you walk away. Took me a few times of it happening to realize that's what it was being fussy about. Especially with a powered hatch, having to stand there waiting for it to completely close to get that first beep is annoying and I wind up manually using the fob at that point as I'm walking away.
What a picky feature If I walk away too fast I'm out of FOB range and it won't trigger. Service manager at the dealership said that I might be walking away too slowly or at least exiting the car too slowly after the ignition is turned off. Guess I have to find the Goldilocks speed. Not too fast and not too slow. Not relying on it would be the best solution but my other vehicles have the feature and I guess I'm programed now so it's a hard habit to break!
