Brakes
Old 05-04-2021 | 06:44 AM
RobertG314's Avatar
Default Brakes
2018 CX5 here. Brakes suck,
Had the brake fluid changed and had new rear brakes installed and the brakes still suck.
Pedal travel is far and it takes a lot of foot pressure to activate the brakes.
Does anyone else have any brake problems ?
Any suggestions to remedy it ?
Thanks in advance
Old 05-04-2021 | 09:01 AM
Conrad 16.5's Avatar
Who did your rear brakes? Was the system put into 'maintenance mode' before the work was started?
Old 05-04-2021 | 09:22 AM
CarpeDiem's Avatar
I wonder why the front brakes weren’t changed, they normally wear out first unless there are other problems. The symptoms sound like air in the lines or the wrong fluid, but there could be other causes. Take it back to the shop that did the work. The CX-5 is not known for poor brakes. Mine certainly don’t “suck”.
Old 05-04-2021 | 02:50 PM
RobertG314's Avatar
Local Mazda dealer did the rear brakes. I assume they put it into maintenance mode, I would think so. .
They were a little better after the brakes were done but it just got worse again.
Old 05-04-2021 | 02:51 PM
RobertG314's Avatar
The front brakes were good.
I had the brake fluid changed too.
It helped a little but it just got worse not too long after.
Old 05-04-2021 | 03:57 PM
CarpeDiem's Avatar
New brake fluid (or old for that matter) will cause a soft pedal if any air was not properly bled out by the mechanic. There may be a leak in the brake system, either in the lines or the master cylinder. Has the brake fluid level been dropping?
Old 05-10-2021 | 11:01 PM
RobertG314's Avatar
Good question but the answer is no. Brake fluid level is the same.
bakari75
11-09-2019 07:51 AM
kingpato
11-06-2009 09:09 PM
bassman843
04-17-2009 12:24 PM
Mazdaboy2600i
12-09-2006 12:34 AM
askperry
08-23-2006 12:27 AM
