CALLISTO - Trans Fluid Change Kit
Old 06-23-2024, 07:50 PM
HighCompression's Avatar
How many inch pounds do you torque your trans pan down, when using a gasket?
Old 06-23-2024, 11:53 PM
For my personal Mazda pan it is more about using about 5 steps. Then rechecking after the transmission is warmed once then after a short drive for leaks or fluid saturation which cause the annoying drip. I torque to 60 inch lbs unless the gasket shows signs of crushing to much then I will only go to 50-55 in lbs.Then it is more or less visually looking to see how the gasket sets and crushes. You can see the torque procedure on my thread .
there is one bolt on some Mazda that the need for sealer on the thread needs to be used. But on my transmission I readied that with a longer pan bolt. Not sure why Mazda didn’t just do that?
For customers it is for Most Mazda’s 60 to 70 inch pounds but I use ALLData for the exact information use it and log the source and torque used on the customers work order. And we always to a short drive and double check for leaks and gasket oil saturation. If done there is neither and with this method it works every time.
Old 06-24-2024, 12:39 PM
The magnet was pretty fuzzy in the pan.
Old 06-24-2024, 12:40 PM
If this was the first time dropping the pan then that is normal?
Old 06-24-2024, 12:41 PM
The bottom of the pan was surprisingly clean for 113k miles. I have done a drain and fill several times over the years though.
Old 06-24-2024, 12:43 PM
um.... wait until you wipe the pan with a clean light color rag!
And I know from those 2 pictures that your valve body is dirty
Old 06-24-2024, 12:45 PM
If you want to see what the material is on the magnet go to my thread and see how I removed and separated the material for inspection on the magnet.
Mazda3 Things I like to do - Mazda Forum - Mazda Enthusiast Forums
Old 06-24-2024, 12:54 PM
So what am I supposed to do about a Dirty valve body?
Old 06-24-2024, 02:23 PM
LOL I keep suggesting that you visit my thread and look at the information there?
Lots of pictures... none technical thread I don't answer questions about most what I do on that thread .. I only post things I have done for my own personal Mazda. But I have as I said a few times service the Transmision which included a couple or more oil analysis.
davidhirst001
02-06-2023 04:59 AM
Rolland Rahr
12-28-2021 08:32 AM
free.ranger
02-29-2020 10:34 PM
adrianbo
11-12-2010 10:41 AM
Quick Reply: CALLISTO - Trans Fluid Change Kit
