CX-5: "Sunken" rear bumper reflector
Hi all,
I've a 2020 Mazda CX-5 Sport with the dreaded "punched in" rear bumper reflector. I've read that this is extremely common as there's a plastic bracket inside the space that promptly detaches with minimum effort/force; Mazda has a service bulletin about this. Since my car is JUST out of warranty. Is there any chance the dealer would do a good will repair, since it's a known issue? Alternatively, have you guys done a DIY repair yourself? Any tips would be appreciated!
This is the Mazda SB:
https://static.nhtsa.gov/odi/tsbs/20...o2sJXFtcIihaGc
You could try to say the issue happened right before the warranty expired, and see if they'll be nice enough to oblige and fix the issue. Presenting the TSB usually makes them do it. If not, than I'd press them and make them budge.
Or if it's an enclosed area, just get a screwdriver, duct tape and sprayfoam.
Slap some duct tape on it and then pull on the tape while wedging a screwdriver in to pull the reflector out. Then use the spray-foam with hose to get some foam in there and let it dry...it won't fall back in again if you foam it.
Actually it turned out I had a few months left on the warranty. When I brought it up,the mouth breathing moron "Service advisor" wouldn't even let me finish, insisting he'd never heard of such a TSB and that sounded like a bumper replacement. I had to bring it up in my phone for him to "verify". Then "they had to order the part because they don't have it in stock" ..(The "part" is just a 3M adhesive product available everywhere) Is it me or has the level of service and competence in most dealerships plummeted since Covid first hit us?
I have to do the same repair, on my 2020. Can reflector be reached by just removing access door? What is the best way to remove access door? I see the two round plugs - are they screws, or just Push In plugs? Thank you.
