CX-5 Windscreen wipers
Hi All,
I have a 2015 CX-5. Front windscreen wipers suddenly stopped working. Wipers are in “park” position with no life. The windscreen washer works fine, so not fuse. Rear wiper is fine.
I’m thinking switch or FBCM, or maybe motor… How do I definitively diagnose?
If it is FBCM, can this be simply replaced, or is there need to configure/set-up with car?
Thanks for any advice.
Cheers, Jim
Cheers, Jim
You can reset the FBMC by disconnecting the battery.
But before you do that you should get a diagnostic scan done (some shops/parts dealers will do this free) which will show the issue (code).
That way you'll know what to fix instead of trying an assortment of remedies that may or may not work.
I say that because the FBCM is over $250, wiper motor $228 and the switch $121 not counting installation.
