CX5 D Engine Oil Level High
Engine Oil level too high as well.
I am also having the issue with engine oil too high. Came on after oil change with 1100 miles on the oil. Refused to take the car back without changing oil. Got a sample of the oil and sent it for analysis, came back the oil is contaminated and should be changed (as I expected it would) but that had already been done. Mazda had the dealer put an OBDII recorder on the car, put 1000 miles on it, they took it off yesterday. Now it has to go to Japan, they changed the oil yet again. 3700 miles on my car, it has had 3 oil changes. Questioning if Mazda knows what is wrong and questioning if I should keep the car.
high oil level warning light
My new 2019 Mazda CX5 Diesel showed "Engine Oil Level to High" at 3400 miles and now again at 6000 miles. According to the dealer, the diesel fuel is found to be mixing in with the oil so their answer is to drain the oil and replace. I saw this happening a lot in Australia (after I purchased) and am wondering if anyone is experiencing this in the US and if the dealer has given any resolutions. Or if anyone has any advice?
Hola, ayer me aparecio el mismo mensaje. la concesionaria dice que lo tengo que llevar y cambiar el aceite (el costo del cambio de aceite es mio) y es por un mal manejo del vehiculo, en pocas palabras no se manejar.
Otras marcas de vehiculos diesel no tienen el mismo problema......
Una posible solucion es sacar el la pieza del filtro de particulas, configuar el computador y nunca mas problemas de por vida del CX-5.
pero encuentro un gran problema de la marca a no hacerse responsable de la version tope del modelo CX5.
GOOGLE TRANSLATION
Hello, yesterday I displayed the same message. The dealership says that I have to take it and change the oil (the cost of the oil change is mine) and it is due to a bad handling of the vehicle, in a few words I don't know how to handle it. Other brands of diesel vehicles do not have the same problem ...... A possible solution is to remove the part of the particle filter, configure the computer and never more problems for the life of the CX-5. but I find a big problem for the brand not to be responsible for the top version of the CX5 model.
GOOGLE TRANSLATION
Hi, can you tell me which dealer you take your vehicle too?
