Door-handle pushbutton no worky in cold weather
bought 2017 CX-5 brand new. In cold weather, the door pushbuttons don't response. The key fob doesn't work either. Sounds like rubber getting frozen and not allowing good contact. Thankfully it takes a minute of pressing, then works, but kinda scary as I was locked out for a minute last time I went skiing. Don't want to be stuck up at mountain! Not sure how to deal with this on warranty as I feel like dealer will just say "they work, we didn't find anythign wrong with them" cuz it won't be cold enough by the time I get to the dealer. thoughts?
This is a photo of a 2017 CX-5 exterior driver door handle. It is the same as my 2014 handle which pulls straight out. Where is the push-button you are referring to? Is this an electrical problem involving the lock or a mechanical problem involving the latch/handle? There are lock de-icers for what you are describing... Cars in Winter have these problems. The dealer is probably going to tell you this.
I don't know what else to call this. Is that not a button on the handle?
You circled the lock cylinder. Spray some of this Bell Lock de-icer where the key goes in and where the handle connects to the door pull and you should be good to go. $5.00 at Walmart. Or, try some alcohol based hand sanitizer on a warmed key and insert it and work it gently until it turns. There are many YouTube videos on this subject also.
If your door is frozen shut, warm it up with a hair dryer until it opens and then silicone spray or PAM cooking oil spray the rubber weather stripping to seal out moisture so it doesn't freeze to the door jamn again. There is nothing wrong with your vehicle.
My apologies. I'm obviously out of my depth. But I do love my Low-tech 2014 even more now...
No apologies necessary. And, without the AKE system, you probably will have fewer issues down the road.
