ECM problem. Error log in post.
Old 06-04-2020, 03:33 AM
Hjalti Vignis's Avatar
I sincerely hope that this ****ty failure does not happen to anyone, not even my worst enemy. Been two months and we are completely out of ideas of what might be wrong. Nothing seems to be wrong but injectors on cyl 2 & 3 are still not receiving any current and do not work.
  #22
Old 06-27-2021, 12:39 PM
NewMazdaUser's Avatar
@Hjalti Vignis
I am experiencing similar issues with my Mazda and have got these codes:
ABS (Anti-Lock Brake System) 1 problem exists
- U0401:00-68 invalid data received ECM/PCM A
SCBS (Smart City Brake Support) 2 problems exist
- U0401:68-28 Invalid Data Received From ECM/PCM A
- U0415:68-28 Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
Did you solve your problem?
  #23
Old 07-03-2021, 05:34 PM
winkybil's Avatar
For the less technologically sophisticated of us, can I get a dumbed-down version on the Media File issues? How do I what type of media file my image is? and where can I find out which ones Nox Vidmate VLC supports? TIA.
  #24
Old 07-27-2021, 05:21 AM
Tiago's Avatar
Originally Posted by NewMazdaUser
@Hjalti Vignis
Hello, Good morning.
I have a similar problem.
In ECM code P2150 In ABS code U0401 and in SCBS U0401 , U0415.
Please solution for this problem.
Thanks and best regards.
  #25
Old 08-01-2023, 05:01 AM
Bossahayi's Avatar
Default Cx5 cylinders not working
If you are experiencing cylinders not working on your cx5 skyactiv please let me know i have found the solution to this problem and if your vehicle is giving you headaches please get in touch
  #26
Old 09-19-2023, 03:51 AM
terry1976's Avatar
hi mate i'm a diesel mechanic got a mazda cx5 2012 2.2litre diesel cylinder no2 and no3 not working swapped injectors around into working cylinders injectors are fine . also replaced engine ecu still the same any ides greatly appreciated
  #27
Old 09-19-2023, 03:57 AM
terry1976's Avatar
  #28
Old 09-19-2023, 09:40 AM
CarpeDiem's Avatar
Terry, Boss hasn’t been back to the forum in 6 weeks, he won’t see your post. Send him an e-mail and ask him your question.
https://www.mazdaforum.com/forum/sen...member&u=91082
  #29
Old 11-07-2023, 06:03 AM
Fiqa's Avatar
Having same exact issue. Anyone found solution to this.
  #30
Old 11-07-2023, 07:33 AM
Fiqa's Avatar
hi i have the same issue, any help welcome
Quick Reply: ECM problem. Error log in post.
