ECM problem. Error log in post.
Old 03-06-2024, 01:22 PM
joetcoop94's Avatar
Default Fault code u0401 and p0183
Originally Posted by Tiago
Hello, Good morning.
I have a similar problem.
In ECM code P2150 In ABS code U0401 and in SCBS U0401 , U0415.
Please solution for this problem.
Thanks and best regards.
hi did you manage to sort this problem with fault code u0401? I’m getting it
  #32
Old 03-06-2024, 01:23 PM
joetcoop94's Avatar
Originally Posted by NewMazdaUser
@Hjalti Vignis
I am experiencing similar issues with my Mazda and have got these codes:
ABS (Anti-Lock Brake System) 1 problem exists
- U0401:00-68 invalid data received ECM/PCM A
SCBS (Smart City Brake Support) 2 problems exist
- U0401:68-28 Invalid Data Received From ECM/PCM A
- U0415:68-28 Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
Did you solve your problem?
did you solve this problem as I’m getting fault codes p0401 and p0183. Thanks in advance, Joe
  #33
Old 05-17-2024, 09:02 PM
SunKa's Avatar
I have the same error codes discovered during investigation or the "thump sound" issue described here (video on Reddit). And I found this official Mazda Service Bulletin describing those error codes, together with REPAIR PROCEDURE. Check whether it's applicable to your VIN first. Basically, recommendation is to replace SAS CONTROL MODULE.
For now I cleared errors, and they not appear again right away. Will wait and see how this thump sound issue progress and when error appear back.
  #34
Old 05-17-2024, 09:16 PM
SunKa's Avatar
And
is a good 3 min video on simple fixes to try, starting from checking and charging battery (makes sense, as I had U3003-16 error code also, which is Battery Voltage: Circuit Voltage Below Threshold).
fabien4455
01-30-2020 07:40 AM
thymebreaker
10-24-2019 10:53 AM
VELOCITY_RX7
06-18-2010 01:55 PM
SpicyMSP
05-12-2009 01:15 PM
Quick Reply: ECM problem. Error log in post.
