Flash drive issues
Flash drive issues
My 2017 CX-5 is having flash drive issues. I have a lot of music on two Flash drives which I keep plugged into the two ports. Ever so often my system will drop the flash connection and revert to a radio station. At that point I can't access either of the flash drives.
When it happened yesterday I removed the flash drives and they were so hot I could barely hold onto them. Once they cooled down they worked again but eventually heated up again and reverted to a radio station.
Is this a known problem and if so is there are remedy for it?
Thanks in advance.
Thanks in advance.
Also I’m using Sandisk flash drives. I’ll try another brand and see what happens.
I'm not saying that will solve your problem and you may want to try a different brand before going that route. Be aware that other brands may have those hidden partitions as well though. I use SanDisk with that partition removed on my 2014 CX5GT without any problems.
Latest software in my market is 70.00.335.
You can probably find pirate copies on the internet.
I would visit your dealer, ask then to check, if its old, ask why it wasn't updated during the last service.
Thanks in advance.
Thanks in advance.
