Flat tire & AWD
Flat tire & AWD
This has happened twice now and I'm not sure what is going on. The first time I got a flat tire and the car started cutting out and barely running. I limped to a parking lot and changed the tire and all was well. This weekend my lot tire pressure light came on while I was on the highway. Within a few seconds the car started bogging down and I could only drive about 50 mph. I even tried switching to manual shift mode and it would not come out of gear. I limped to a gas station and filled up one tire that was low (20 psi). Restarted the car and everything was fine. Any ideas on what is going on?
I'm sorry I can't help with your question, I personally have never heard of an issue like this occurring but I'm sure you will get an answer. But I would suggest checking your tire/tires for a leak. I would also suggest keeping a tire inflator in your car.
Am I doing the same thing? Almost, but not quite.
While I replied to the OP stating I did not know the direct answer to his question, I offered him two worthy suggestions - taken from my own driving experiences. I hope others can offer a specific answer - if not, perhaps the OP can call Mazda Service. But I do hope the OP will accept my (albeit limited) response in the spirit in which it was offered.
On a separate note, the I also saw that they say if the front goes flat, never install a temporary on the front. Handling will be affected, you could lose control on ice or snow bound roads, Move a regular tire to the front and install the spare on the rear.
Makes sense why they say not to put a spare on the front, but I just never saw that instruction before.
Really interesting behavior. It sounds like the car is going into some ECU governed limp mode, which I cannot easily find in the manual. The behavior is consistent with what you are supposed to do with a flat and temporary tire. Do not drive over 50 mph, long distances, etc.
Interesting about the front flat and handling; I had no idea - but thanks for bring it to our attention.
