Front Passenger Seat Removal Info
Old 07-03-2012 | 06:06 PM
13CX5STL's Avatar
Default Front Passenger Seat Removal Info
Considering removing the passenger front seat in order to install a component rack on the floor where the seat is now. Do not need the seat and would safely like to remove it. The seat rails would remain but just the seat and seat back will need to go. My question, Unplugging the connectors under the seat will apparently affect the air bag system on the passenger side. Anyoneelse have any other advice on removing the seat. Thanks.
Old 07-08-2012 | 08:37 AM
13CX5STL's Avatar
Update. No replys or suggestions apparently means that this procedure has not attempted yet. I looked closely under my seat and found several electrical connections attatched to the seat rails. I guess these are sensors for the airbags in case of impact where the seat would thrust forward with enough energy to trip the sensors and deploy the side airbags. Not sure if the removal of the seat is going to work as I had hoped. Just wonder if I unplug the sensor connections, it will effect the whole system. I think I'm going to have to contact the dealership and ask the tech advisor. Was hoping to maybe catch a tech surfing these forums for advice.
Old 07-09-2012 | 02:56 AM
If you unplug the connectors your entire airbag system will be defective & non operational.
Old 09-20-2012 | 07:56 PM
jeff12481's Avatar
Is there any way to remove the back off of the front passenger seat? and will that affect the airbags?
N628PW
01-19-2014 09:08 PM
jeff12481
09-17-2012 08:27 PM
silver71
01-14-2011 05:30 AM
austintitus3
12-29-2006 02:59 PM
futurevip
08-04-2006 07:46 PM
Quick Reply: Front Passenger Seat Removal Info
