Intermittent 'chime' sound
2021 CX5 Turbo, 16K miles. I'm getting an intermittent 'chime/bell' noise when driving. Similar to the fasten seatbelt sound but coming from the center of the dash. No notification lights, no correlation to speed.
I've been through the systems menu looking for notification alerts with no success.
Any ideas?
Any ideas?
Lane departure
Any ideas?
Any ideas?
Don't think so. In addition to the dash lights warning, I also have the steering wheel vibration enabled. That system is working normally. It also occurs on my 2 lane road without any centerline.
Any ideas?
Any ideas?
(Ver. 7000C0A-NA03_11046) fixes these software errors (bugs):
• The vehicle icon rotates when using the navigation with head-up mode.
• The system reboots when operating the audio source screen.
• If another incoming call comes in immediately after the hands-free call is ended, it is automatically accepted.
• Audio tracks stop playing or are muted when playing them using the Apple CarPlayTM.
• The system may reboot.
• A beep sounds after every couple of minutes.
• Language setting may not be accepted correctly.
• The screen shows “Phone in use” message and it stops playing audio tracks while playing audio tracks
using CarPlayTM and refusing the incoming call.
• The audio track may not pause when pressing the mute button.
• The screen freezes when smartphone receives messages under Bluetooth® connection.
• The system does not resume a play list after editing it for an USB audio device.
Do you have the 10.5" display? If so, check the System Information to see what software version you are running. If it is 11038 or earlier, this could be part of a software glitch that was fixed in 11046 and later. Here are the release notes for 11046:
Any ideas?
Any ideas?
Another great suggestion--I forgot about this. And it's configurable for +0, +5, or +10 (at least on my '23 Signature) so it could be happening at any of those thresholds, although I assume if you're only hearing it every so often it's probably set at +10.
Not the speed alert,it happens from 15 to 70 mph!
My software is version 11022. I tells me there is no newer update available!
Gracenote Database is 1.1.1.02071. When I ask to update I get system error message, can't connect.
I'll contact the dealer next week.......
