Liftgate open only 1 foot and stop
Mazda Cx5 2018 issue with my liftgate . The liftgate open only 1 foot stop and beeps 3 times . I try the diagnostics the problem without scanner and google not easy . By experience problem is with the control or electric strut ,sensor ? I already remove negative battery cable same issue . It look like the system is in security mode and stop the gate ? . Any suggestions will be appreciated . Thanks .
Bad fuse and/or battery can cause this problem.
Check the fuse and load test the battery and replace it if it fails the load test.
Average OEM battery life on 2015 and later model vehicles is only 3-5 years.
If your battery is the original don't bother with the load test, it needs replacing.
