Lights won't come on when rear passenger door opens
Old 11-25-2021 | 06:45 AM
Ecx5mazda's Avatar
Default Lights won't come on when rear passenger door opens
So this is driving me crazy. The lights won't come on when rear passenger door is opened while the car is running. However when the car is off and the door is opened it turns on just fine. Does anyone else experience the same issue? Is there a resolution for this?
Old 11-29-2021 | 03:27 PM
Chas2's Avatar
Is there anything in the manual about how interior lights work do not work?
You don't say what model year you have and what trim you have. The 2021 has two different types of systems
Rear Map Lights
Type A
When the overhead light switch is in the door or off position, press the lens to illuminate a rear map light, and then press the lens again to turn it off.
NOTE
 Once the rear map lights have been turned off, they will turn on and off depending on the position to which the overhead light is switched.
 The rear map lights will not turn off even if the lens is pressed in the following cases:
 The overhead light switch is ON.  The overhead light switch is in the door position with the door open.
 The illuminated entry system is on.
Type B
Press the switch to illuminate the rear map lights, and then press the switch again to turn them off.
NOTE
 Once the rear map lights have been turned off, they will turn on and off in conjunction with the overhead light operation.
 The rear map lights will not turn off even if the switch is pressed in the following cases:
 The overhead lights turn on by operating the overhead ON/OFF switch ( ).
 The overhead lights turn on in conjunction with a door opening/ closing.
Old 02-07-2024 | 09:00 AM
Smaza1970's Avatar
Default Mazda 5 left rear door open not showing on dash
Hi
I have a 2011 mazda 5 and all doors except the rear left will activate the interior lights and show as door open on the dash, I changed the switch over from one side to the other and still the same and the switch from the left works on the right.
So my guess is somewhere the cable must be damaged anyone know where this runs in the car?
I'm thinking I may have to remove the rear seat and the side internal panel to trace the wire and check for a fault or does the cable run through the roof liner to the interior light,
anyone know before I strip out panels?
Many thanks
Cornywillis
02-15-2020 04:45 AM
Volati20
07-20-2018 11:38 AM
TA/Hawk
12-30-2009 04:41 PM
afm
11-11-2008 05:31 PM
esloyer
09-04-2006 07:31 PM
Quick Reply: Lights won't come on when rear passenger door opens
