Looking for recommendations
Cooling shouldn't be an issue, whereas heating can be as you don't want a fire.
I did a quick search and only found two manufacturers out there that make covers compatible with heated seats.
But then again, I didn't search that hard as having leather seats, I don't use seat covers.
I found these two.
Shearcomfort
Covercraft
I would suggest checking to see if Mazda allows you to put seat covers on without voiding the warranty.
Oh, and welcome to our corner of the www
I found these two.
Shearcomfort
Covercraft
I have used these for years. I also have custom added seat inserts using Panther Leather and factory heated seats. They are very durable look good available in a few colors and very easy to install. And the price is right!
I should add that when first installed I used the high heat setting for a couple of days so the seat cover conformed to the seat shape and looked more like a factory seat rather than a seat cover.
Although they do not state heated compatible the material is flame retardant and will not harm fabric or leather factory heated seats. As for the Warranty regarding the seat from MAZDA, IDK however there is nothing that is worded it would void a warranty claim having to do with the seats either?? You are not modifying anything. I do recommend if curious to contact MAZDA Corp direct and not a dealership inquiring about that concern.
I found these two.
Shearcomfort
Covercraft
I found these two.
Shearcomfort
Covercraft
