Mazda CX-5 2021 Monitor Blind Spot
Hello,
I need your help.
Blind spot module on the left is defective (damage to the car)
I am asking you for help on this topic.
I need your help.
The problem is that the lokal dealer writes to exchange for two of the same. Which is not true!
The 2018 seris alert attached, but does not provide information on the second segment of the two-letter label. There is only information on the lower part of the alphanumeric label.
I have to look for information myself
Maybe one of you will be able to help me.
I'm counting on your help.
If both modules have part numbers that are KB8C-67Y30E (suffix E) or lower, proceed to next step.
If any module has a part number that is KB8C-67Y30F (suffix F) or later, this service information does not apply. Suffix F or later mismatch is OK.
Step 1, bullet point 2 says hardware revisions "F" or higher are not a problem.
Your hardware revs are both higher than E, so the bottom labels don't matter. Your hardware revs are higher than F so mismatched hardware revs are okay.
