Mazda CX-5 dashboard sign issue
Hi I am having some issue with my Mazda CX-5. It is a 2016 model and has 72000 mileage. So what happened is- I had a flat tire few days ago and I had to change my tire. It was a left rare. I changed only one tire. So after that from next day- in the dashboard they are showing my tire pressure light is on and as well as traction control sign. Sometimes it was also giving me trouble staring the car. I did a tpms check and car battery check. So I found my battery has very low charge. But the sensors in tire looks fine. So I changed my battery. And it did not work. I am not sure what is happening and what I need to do next?
ThanksBoni
ThanksBoni
Dashboard sign issue? What are you talking about?
You didn't say what tire you put on as a replacement, Was it the same as the other three tires?
Was the air pressure checked and set the same as the other tires? Was the system reset afterwards?
Having trouble with starting the car has NOTHING to do with the tires or the TPMS system.
Speaking of the TPMS system. Your 2016 did not come from the factory with any kind of TPMS sensors in the tires. 2016's use the ABS system to determine if the air pressure is low or not.
Lastly, if your battery was low that could explain the error lights you're seeing. You said that you changed your battery and it didn't work. What didn't work, exactly?
The OP’s post is confusing, no doubt. But since his battery was low - why? Bad charging system? Left the lights on? More likely the battery is shot, which would explain the “dashboard signs” issue. He needs to take his CX to a large auto parts store and have his battery load tested, a voltage check is worthless. He likely needs a new battery….or not since we really don’t know much about his situation.
