New CX-5 wind noise after ppf
Hey all,
Got a new CX-5. Had paint protection film installed on hood, front bumper and headlights. Also had windows tinted.
Since then, there seems to be a lot of wind noise coming off the side mirrors at speeds above 40mph.
Xpel place said they’ve never heard of ppf causing issues and they did not remove any parts or panels during install. They did check the seals around the doors and said it looks fine.
Dealer can’t get me in for a month, so driving around a loud new car isn’t appealing.
Any suggestions?
Any suggestions?
Never ever had that happen. I use to install mostly 3m protects for a couple dealerships in the San Jose Ca area. There should be no physical reason the film could make any noise. I would carefully examine the body parts and make sure nothing was displaced?
The so called rain protectors or miss termed wind protectors WILL increase the noise on newer MAZDAs because they disrupt the air flow and cause turbulence. But they do well at reducing rain and snow if you drive with the windows slightly or down in those kinds of weather?
But yeah, I immediately noticed the wind afterwards.
Hoping it will be something easy. I don’t have any other items installed like rain guards on side of windows or roof bars or anything. 🤷🏼♂️
Even took it to another shop associated with a body shop to check the seals and they said it all looked good, but they did acknowledge the wind noise from side mirrors and said something might be kicking the wind up from front of vehicle just enough to cause noise on side area by mirrors.
Yeah, it is strange. They claim they didn’t adjust or do anything aside from install.
The front end in the stock state or parts will not cause a deflection to the side of the car and upwards to the mirrors?
Is the noise on both sides increased or just the drivers side?
I presume with ALL the windows fully up?
This has me vey curious to help solve.... hahahaha!
Can you post some pictures?
But to be clear, it did not have the loud wind noise before the install. I’ve driven 2 other new ones at the dealer since then to compare with mine and they were quiet.
If that is the new position then I guess its correct?
As an experiment push the mirrors full collapsed (for parking) and full forward position (bumped protection) and see if the noise changes and if so, how?
You may have to remove the film, or turn up the radio if it annoys you . Just kidding , this is very bizarre and strange .Never heard or seen anything like this B4. Is it possible the window tint installation stops the windows from sealing properly ?
