New CX5 - Stain on Dashboard
Hello fellow Mazda members,
I took delivery of a new Mazda CX-5 and I am seeing a stain or discoloration on the upper part of the dashboard. I tried to remove it using p&s interior cleaning, but no luck.
https://psdetailproducts.com/products/xpress-interior-cleaner-doubleblack-collection
What this could be? Any help is much appreciated.
Thank you.
Thank you.
Impossible to tell from the photo. When I picked up my ‘21 the dealer had done a spotty job of applying Armor all or whatever protectant they used, resulting in an uneven glossyness. Not sure if this is your issue, but I applied a good coat of Aerospace 303 and that made the dash look even.
Thank you CarpeDiem. I reckon dealer applied some sort of cleaning agent and did a poor job of wiping it out, and let it dry, given the entire car had swirl marks when I took the car out in bright sunlight.
Yeah. I will try to take a better picture and paste it here. And I will give Aerospace 303 a shot.
Thank you so much. I have never used mild soap water for cleaning. Thanks. Is it safe? I will give it a shot today and reply here.
From manual:
Instrument Panel Top (Soft pad) Maintenance
Extremely soft material is used for the soft pad surface. If the soft pad surface is rubbed harshly with a dry cloth, it could result in the surface being damaged and leaving white scratch marks.- Wipe the soiled area with a soft cloth soaked in a mild detergent (approx. 5%) diluted with water.
- Wipe off the remaining detergent using a cloth soaked in clean water and wrung out well.
I have no issues what so ever
From manual:
