Sirus XM issue
#71
Thanks for your kindness, JAMizer. When I tried to load the link it came up with an error in loading each time I tried. Still unsure what I would do next to get in correctly into the car, but I will work on this.
Appreciate your research and advice...much appreciated.
#72
Confirm link
https://my.hidrive.com/share/hsodpqja.l#$/
Then select
Mazda CONNECT Firmware
Then NA N
Sorry I had to edit to fix the link.
The NA N is for North America (i assume you are from that area).
Download all, and follow the instructions. Takes 30 or so minutes.
Then select
Then NA N
#73
So far...so good
With the most current firmware I have yet to have a SiriusXM failure. That's good.
While the infotainment system can be a bit of a challenge to get use to, after having the car for several months I like it now. The fact you can change channels and it starts at beginning of a song is a nice feature, as is the one hour replay feature.
Android Auto interfaces well too.
Hopefully the days of getting a XM Radio failure are over!
#74
Latest Infotainment Update
Hopefully today has finally fixed the Satellite Radio issues for good after 16 months. As a Bonus, Touch Screen is now allowed! Will see if the issues are gone after some time since they were always intermittent.
#80
Hello, I want to do this firmware update but I have never done it before, and I want to make sure I don't screw anything up. In step 9 on the PDF in the link you posted, it says to insert a "prepared USB memory stick". Do I just use a blank USB stick? Or do I have to load software onto that USB stick first? Thanks!
