Sub woofer install
Sub woofer install
Hi i have completed every thing there is to do as far as installing the sub. It has a built in amp and i'm using a LOC. My 2020 cx 5 with Bose speakers already has a factory tuner amp in the glove box and i was trying to tap into it. i can't tell which wires i need to tap to get a signal. Any solutions? i'd like to get the extra sub installed and keep the car factory as possible. PLEASE HELP
You cant tap into the wires. With that factory BOSE system its likely you are going to need Line out converter or similar. If you just tap into the wires you can damage you Bose system and possible the amp in your sub woofer?
You may (should) want to contact the company that you purchased your subwoofer unit from?
I had to finally go with a LC6i and run all separate amps to power all the speakers.
Contact Audio control and see if they have any updates for factory BOSE system specifically in Mazda's.
I hope he does not blow the BOSE amp .... which is why I did not give this same wiring diagram or indicate which speaker to tap into! You can not just old school tap into speakers on a Mazda designed by BOSE system from 2015(aprox) and newer for Mazda system
Just a Caution for the op and others!!!
